This is my first build. After connected all the parts and pressed the power button, nothing happen, none of the fan and light is on. no beep.
here is my build:
CPU: i7-930
MB: GIGABYTE GA-X58A-UD3R
PSU: Antec EarthWatts EA650 650W
RAM: CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3
Case: Antec Nine Hundred
Now I only connected the 24-pin power and 8 pin CPU power connectors, one RAM on white slot, Video Card, CPU and cooler and all the front panel headers.
Before i post here, i already did the following tests:
1.I triple checked all the connections and plugs, and they are correct and firm( read the manual for at least 2 times)
2. I tested the power supply with a paper clip, it worked.
3. I tested with another video card.
4.I used the original CPU cooler, so no Thermal Compound is pasted( it came withe the cooler).
5. I switch sides for the front panel header cables since they didn't say about which is positive and negative. I believed that I tried out all the possible ways( only 3 headers).
6. Tried RAM for 3X1, 2X1, 1X1, both white and blue slots.
Beside RMA the board, is there any suggestion? Thanks for any of your help!
here is my build:
CPU: i7-930
