Every Flash Drive Read only and write protecetd
Hello,
Every Flash drive I plug in my computer it says that it is write protected. It won't let me copy information to it at all. I can plug them into my other computer and they work fine. Thank you in advance for your help.
2 answers Last reply
More about every flash drive read write protecetd
  1. bruce_d39 said:
    Hello,
    I have tried the safe mode reformat too and it said that it could not format because it was write protected. I have also tried a low level format which did not work either.
  2. I couldn't figure out how to do this either, but then I found the eHow page for it!
    http://www.ehow.com/how_5103741_reformat-flash-drive-mac.html
    This works! it's great :D It's really simple - just go into 'utilities' -> 'disk utility' -> 'erase' -> then it should be all good
    N.B. Before you 'erase' they external drive, make sure you have a copy of the files elsewhere, otherwise they will be 'erased'
Flash Media Read Only Flash Drive Computers Storage
