Hi everyone at Tom's Hardware!
This is my final build (the one I would like to purchase in a short period of time). The reason for why I'm posting here is that I would like to know if these parts are compatible/ or not compatible with each other:
ZOTAC GEFORCE GTX 480 1536MB PCI-E DVI/HDMI
SAMSUNG DVD±R/RW/RAM DL 22X SATA
DESKSTAR 7K1000.C 1TB 7200RPM SATA/300 32MB
CORSAIR 6GB DDR3 XMS3 INTEL I7 9XX PC12800 1600MHZ CL9 (3X2GB)
INTEL CORE I7 950 3.06GHZ 8MB S-1366
COOLER MASTER MIDITOWER CM 690 II ADVANCED ATX BLACK
For example, does my PSU support my motherboard and vice versa? Because I'm really confused in this ATX12V/EPS12V business (link to psu and mobo down bellow):
ASUS P6X58D-E X58 S-1366 ATX
http://www.asus.se/product.aspx?P_ID...DbB&templete=2
CORSAIR AX 1200W PROFESSIONAL SERIES MODULAR PSU
http://www.corsair.com/products/ax1200/default.aspx
Q1 - Does my power supply support my motherboard and vice versa (such as the right type of CPU and MOBO power connections/cables?
Professional advice/help is required!
Best Regards
/M9A2
Best Regards
/M9A2
