Hello,
I just bought a Toshiba Satellite laptop advertised as having a "dead hard drive". I tried booting it up just to see what was going on and I'm not sure that's the case (but don't know enough about computers)
Anyways, on boot up it says something to the effect of "no bootable device, insert one and hit any key". If i insert either a disc or USB drive with an OS (I've tried win 7 and vista) they both freeze shortly after the splash? screen (I get the animation as if the OS is loading) and then black screen that I can move my pointer around on.
Then I got on bios to poke around and the laptop detects the hard drive and correctly identifies it (model # and size) making me wonder if maybe the HD isn't actually that sick afterall? I chose an option like "restore from HDD" or something to that effect and the same thing happened, I got to a splash screen and it froze.
Does this sound like a dead hard drive to you expert computer geniuses?
I'm fine with it being a dead HD since that's what I bought - if it's a problem with the motherboard I will probably return it, as that kind of a problem is far and away over my head.
**EDIT** I tried installing an OS with the HD removed and I could progress further, up to the point where I had to choose a hard drive to install onto...I got stuck there because I had no options.
