Advice on gpu and case. + overall build thoughts
Approximate Purchase Date: 2 weeks
Budget Range: 530$
System Usage from Most to Least Important: gaming, programming, and web surfing
Parts Not Required: everything but gpu and a case
Preferred Website(s) for Parts: any site that is ships to Canada * cheapest price Obviously*
Country of Origin: Canada
Parts Preferences: by brand or type : not biased in any way best bang for the buck
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution: 1920x1080
parts already ordered and owned
x3 720be 2.8ghz am3
212+ Cpu Cooler
CORSAIR CMPSU-750TX 750W
ASRock M3A770DE AM3 AMD 770
APEX Vortex 3620 SGCC / ABS ATX Mid Tower
2x2gb 1333 ddr3
im planing on spending about 500-600 on a gpu and case
im thinking that haf 932 and the gtx 470
unless the case i have now would prove sufficient to cool these components any other recommendations ?
personal thoughts on gtx 470>?
and haf 932?
4 answers Last reply
More about advice case build thoughts
  1. 1) I would get the HAF 922 over the HAF 932. It has similar performance, size & cable management at a lesser price.
    2) I would hold off on your GPU purchase, as the ATI 6000 series is to be released very soon & soon to follow the Nvidia GTX 580 (what the GTX 480 was meant to be with all CUDA enabled). This will 1) provide better performance & 2) drive cost down on current cards. Also, I recommend the EVGA GTX 460 SC EE over a GTX 470. They are close in performance at a lower cost with better power & heat consumption.
  2. EVGA GTX 460 SC EE is 250$ AT NEWEGG while the gtx 470 is 280 so im leaning towards this..
  3. If you haven't purchased the PSU, I would look to drop it down to a 650w or 550w (specially with a GTX 460) power supply. You are running a single card motherboard so you won't need more than a 650w PSU.
    Also, you can look at the Athlon II X3 450 over the Phenom II X3 720, if not already own... http://www.anandtech.com/bench/Product/189?vs=83
  4. sorry i should have been more clear i already fixed main post but i already own alot of the parts everything but my gpu and case has been ordered
New Build GPUs Cases Systems
