Asus sabertooth 990FX mobo DRAM_LED light is on?
Hey, just got done wiring my pc, went to boot up and got a black screen. When I boot up, the CPU LED goes red but then turns off, but the DRAM_LED light stays on. I hold the MemOK button for ~3sec, it flashes for a bit and then nothing happens. What's wrong here?
Reply to wargall
5 answers Last reply
More about asus sabertooth 990fx mobo dram_led light
  1. Use the troubleshooting tutorial to slowly and carefully work thru the possibilities.
    http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
    Reply to beenthere
  2. Is your RAM seated properly? They should be level and not at an angle.
    Also what type of ram are you using? Is it a paired memory kit or just some sticks thrown in there?
    Reply to Chainzsaw
  3. It seated properly, both are level. Currently using http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
    I just reset my bios but that didnt work either
    Reply to wargall
  4. They could be in the wrong slots, I have them in the two furthest from the CPU, I'd put them both in white but my heatsink covers the other two...
    Reply to wargall
  5. Hi I just rebooted my pc and I have got the problem that my dram led stays on. I have got the system for almost 2 to 3 years now and never had this kind of problem.
    If anyone has an solution for this let me know.
    System.
    be quiet! Shadow Rock TopFlow SR1
    AMD FX-8350, 4,0 GHz
    Cooler Master V1000, 1000 Watt
    ASUS SABERTOOTH 990FX R2.0
    Corsair 16 GB DDR3-1866 KitMSI 8GB D5 X R9 295X2 R
    Reply to stef19935
Ask a new question Answer
Motherboards DRAM Light Boot LED Monitor Sabertooth Product
