I just bought a new AMD build PC and I want to do some cable management. However, I'm a bit worried that I will be doing something wrong since it's OS is already installed and have few important files already stored that I don't want to lose.
What I want to ask (or clear) is, if I remove every cables I can find inside my rig, will anything get corrupted? Or maybe parts will get damaged? I'm having a hard time finding a cable management guide that can answer those questions since most of them are doing the cables before installing the OS.
I asked some friends and they're not giving me the same answer. It just makes me get confused more. Hope someone can clear this up. Thanks!
*Not sure if I posted it in the right section, but I hope I did.
