Hello,
I recently purchased the asus rampage 3 formula motherboard and the corsair deliminator 3 X 4 g RAM kit. After I installed the RAM in a 1,3,5 configuration the computer would not post. After I moved all of the RAM one position to the left 2,4,6, it posted but displayed that my RAM was running at 1066 speed. I then updated the bios for the motherboard off of the asus website and turned on the XMP profile and was able to clock the RAM at 1866 but with providing higher than normal voltage to the RAM, I believe it was around 1.7.
Does anyone have this motherboard/RAM combo and experienced the same issue?
Any insight regarding the issue would be GREATLY appreciated.
Here are the links...
First the Mobo-
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131666&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
Now the RAM-
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145329&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
Thank you
First the Mobo-
Now the RAM-
Thank you
