Und problems with audigy
greenday5494
6
Could someone help, please
Well basically, i bought a basic soundcard (SoundBlaster Audigy SE 7.1) in order to replace my onboard which i thought broke. I put in the soundcard, which by the way, did not fit totally, it went in, but there were some pins not totally inside of the PCI Slot, but i turned on the computer, and windows deteced it, installed drivers for it and everything.
So i set my playback devices to SB Audigy by right-clicking the sound icon, ....and no sound plays. i made sure everything was plugged in, still no sound
i have windows 7 64bit
The little sound icon in the corner looks like it's play sound, but no sound is coming out at all... this was the same EXACT problem that i had before.
The only things I can think of are:
1) speaker volume (software) is too low (set to 50%)
2) your speakers don't work (as mentioned above)
*Also, go into your Device Manager and look for any CONFLICTS or other issues. Sometimes if you don't install the main driver for your motherboard, other devices plugged into the motherboard won't work.
