Solved
Need cable sleeve for hdd led and power button wires
The USB cord is black, sata cord is black, going to get another black sata cable, then all I will need to do is the hdd activity led wire, which you can see
Any suggestions on this?
I was thinking shrink tube/wrap and some 1/8 cable sleeve, but I've never done this before
Pay no attention to the power supply wires, I'm getting a modular power supply soon.
http://img543.imageshack.us/img543/9574/cableneeed.png
7 answers Last reply Best Answer
More about need cable sleeve power button wires
  1. Best answer
  2. Radio Shack
  3. Best answer selected by scarslilpyro.
  4. mosox said:
    wow that's perfect, thanks!
    So will I have to take apart the entire front panel to hook these up?
  5. You can cut the existing case wires close to the front panel and also cut off the male connectors of those wires above and connect the two.
    With splices/posi-locks/soldering?
    I would rather just take the front panel apart and hook it up the right way.
Power Supplies SATA Cable Hard Drives LED Monitor Components
