P8P67 SLI problem
Hi there im in need of a little help people !
1. Me and my bro upgraded to new computers back in march we have the same systems apart from CPU and SSD i choose to not get a new monitor and put all my money in to the system but my bro got a new BenQ which can get 1920 x 1080 and im still using 1280 x 1024.
2. We both ran Mafia 2 benchmark and he gets over 100fps at a resolution of 1920 x 1080 and i get about 55 - 60 fps at the lower resolution of 1280 x 1024 now i thought this could be the monitor holding SLI back but ive recently been told this would'nt be the case.
3. I have tested both MSI 560Ti's on their own in the system and i get the same 55 - 60 fps that id expect to get from one card so in SLI ive been getting NOTHING !
4. Now ive put the cards back in the system refuses to see the 2nd card ive uninstalled drivers and reinstalled them to no avail would anyone have any idea what this could be ?? would a reformat be an idea ?? or could my motherboard be screwed ?
Hope some of you's can help as id really like to get this sorted !
Thanks peeps !
Thanks peeps !
More about : p8p67 sli problem
1. Lower resolutions to a point generate higher frame rates.
2. Depends on the Details, AA, DirectX, Physics and if looking at High/Low or average frame rates. Apples to Apples comparisons.
3. Make certain SLI is enabled in the nVidia Control panel and the SLI bridge is connected.
4. Test the GTX 560 individually in the top PCIe slot, AND then in the second PCIe slot to make certain BOTH the GPUs AND PCIe slots are working.
Related ressources
- P8P67 pro or Sabertooth p67 with i5 2500k for oc and sli - Forum
- Asus P8P67 Pro/Deluxe 3-Way SLI ? - Forum
- Does the asus p8p67 pro support proper SLI - Forum
- Asus P8P67 Deluxe mobo sli question - Forum
- I5 2500K 87 DEGREES IDLE! + Asus P8P67 Evo Problems NEED HELP! - Forum
jaquith said:
1. Lower resolutions to a point generate higher frame rates. 2. Depends on the Details, AA, DirectX, Physics and if looking at High/Low or average frame rates. Apples to Apples comparisons.
The confusing part is that his *lower* resolution is getting lower FPS than his brothers Higher Res, lower powered computer.
ive just looked at the manual for the ASUS P8P67 Pro 3.0 Rev and it has 3 PCI E slots blue grey and black and now im wondering if ive got them in the right slots ! ive got blue and grey populated ! Would either of you 2 know if this is correct ?
Nvidia Control panal does'nt even give me the option for sli it can only see one card ! SLI bridge is 100% connected !
Testing in the 2nd slot is this ok to do ? its not gonna cause any problems ?
yes, testing the second slot is fine. It won't cause any problems.
Yes you want it in the Blue and Grey slots.
My steps would be....
Remove SLI link and boot with Card A in blue slot, verify in OS card is functioning properly.
Switch Card A with Card B in blue slot, again verify in OS
Remove Card B from blue slot, place Card A in grey slot, verify in OS
Switch Card A with Card B in Grey slot, verify in OS
if all those steps are working place Card A in blue, card B in grey, boot
download most recent certified nvidia drivers (280.xx) and reinstall
Go into the nvidia settings and see if both cards are showing up,.
thank you both very much !! just tested the 2nd slot with a single card in it and was greeted by POST firing beeps at me and no signal to the monitor !!! id say thats a sure fire way of saying my white PCIe slot is DEAD ! this is the 2nd ASUS motherboard ive bought in my life and the 2nd to mess up !! i sooo shud have gone with gigabyte ! cant believe it !!
Just to make certain, some MOBO's won't run the 2nd PCIe for GPU -- re-install the SLI in both the top 2 PCIe slots to see if the 2nd GPU works in SLI now. In your manual on page 2-14 it shows 'Single VGA...' N/A.
For now it seems both GTX 560's work. So try re-seating and test the SLI again.
edit: On many MOBO's you can pick and choose the PCIe slots for the GPU and some MOBO's have PCIe switches -- yours doesn't. I should have popped open your manual.
Download GPU-z -> http://www.techpowerup.com/gpuz/ and see if it 'sees' the second GPU.
Note the pop-up tab in the lower-left:
martynpops said:
never have had any ATI cards always bin with Nvidia GPU-z only saw 1 of my cards !!Shutdown and remove the SLI Bridge AND try the brother's SLI BRIDGE AND play musical PCIe 2 x 6 Pin connections with both GPUs and see if GPU-z 'sees' it now or if you have a different problem.
IF NO CHANGE then IMO BAD MOBO
Since you tested them individually and they work individually the possibilities go way down.
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] ect-gtx560
- ForumAsus P8P67 good for sli gtx 580? Or better option?
- ForumCan't install any OS on Asus P8P67 Pro
- Forum550w power supply for p8p67 ?
- Forum[Homebuilt] Asus P8P67 Pro Rev 3.1 Red blinking LED on VGA, CPU & DRAM
- ForumP7h57, i5-760 and 2x8gb
- ForumSLI and memory utilization? 16GB
- ForumPower Problem , Low Fan Speeds , etc. HELP
- ForumP8P67 PRO Boot issues (red light)
- ForumRAM Problem
- ForumReplaced P8P67 with an identical MB - but now Windows just BSODs!
- ForumAsus M4A79 Deluxe mother board Cross fire problem
- ForumAsus Rampage III Black Edition 2 A1,A2 slots weird problem
- ForumEVGA Z68 SLI - PCI Slot Not Detecting
- ForumASUS p8p67 Sound Port Recognition Problem
- More resources
Read discussions in other Motherboards categories
