Hello!
Since today my computer is unable to start up I think its overheating! Which is rather weird.. A friend of mine built my computer about a month ago and a few days ago my computer just shut down all of a sudden! And not a friendly shutdown, just -woosh- turned off.. And when I tried to start it again it happened again so I just left it for a while. Then later I managed to start it again and downloaded that RealTemp program. My CPU was 100 degrees!
Pretty much whenever I do something it goes to 100 degrees & then it shuts down because its getting too warm. Now I have installed 2 new fans & my friend is going to install a new processorcooler next tuesday.. But for some reason I don't think it's going to fix the problem.
At this moment, my computer can run for about 30 seconds if I'm lucky. Last night I managed to start it and my CPU was a steady 100 degrees.. No more no less.. And then it shut down again. I tried to check the temperature in the BIOS as well, in there its 86 degrees and it has never changed besides one time.. then it went to -31 degrees.
Now.. I dont know what to do! Do you guys think the new processorfan will solve the problem? Can it be possible the temperature thingy broke which causes it to think its 100 degrees?
Does anyone know what the problem is?
In case I need to add this I have a:
Intel Core I7 950 3.06 Ghz Quad Core (not overclocked!)
MSI X58A-GD65 Motherboard
