GTX 260 SLI problems?
I dont know what the problem is... i bought a brand new gtx 260 on sale from my local PC place since it was closing down and i know the owners...he sold it to me for 100$....When i play games i get constant Screen Shaking and tearing... In all the games i play it happens...
I have a
MSI NF 750 G55 Motherboard
2x GTX 260 216
4GB Corsair ddr3 ram
Antec Earthwatts 650 PSU
300GB HDD
Phenom 2 955 BE stock clock
what could be the problem?
5 answers Last reply
More about problems
  1. Try using the new GTX 260 only and see if that has any problems. If it does, try updating the drivers and see if it solves any problems. If there are no more problems, try SLI with the old GTX 260. Otherwise you might have a faulty card.
  2. They both work....tested both individually and they both work.... I read in another post that a faulty sli bridge could be the problem...
    But the performance increases just like it should on all games...
    all i get is vertical screen flickering...
    EDIT: But if i disable SLI it works not flickering or anything... andmy cards are BFG....and well BFG is closed i guess...and i cant contact them for help...
  3. Try updating your drivers - it might fix your SLI issue. Otherwise it'd be the SLI bridge I suppose.
  4. Also try turning on V-sync in the game options, and see if it helps.
  5. Their updated to most recent... the 258.95...
    I did some messing around and noticed that the SLI bridge only works in a certain way....
    Ill order it rigth away....
Graphics Cards Gtx Games SLI Graphics
