AT&T DSL and Linksys problems
Last response: in Wireless Networking
August 5, 2010 12:20:12 PM
Hello,
Yesterday I set up my new DSL service and while I can connect to the internet just fine via LAN, I can't seem to get my wireless to work. I can connect with the computer connected directly to the modem and directly to the Linksys router but if I try to use the wireless it doesn't work. Any advice? I've tried many "fix's" that I've read on the net including attempting to put the modem in bridge mode (which resulted in NO internet access) and also changing the router's IP to 192.168.2.1 instead of 192.168.1.1
I'm not sure of the modem's model number, it says "Westell, ADSL2+ Router, Style MSTATEA" on the bottom...The router is a Linksys WRT54GL
More about : dsl linksys problems
August 5, 2010 10:40:03 PM
Well I just found out that it's only the laptop that's running Win 7 that can't connect. My other laptop which runs XP and my PS3 both connected wireless just fine...
m
l
August 5, 2010 10:47:27 PM
Ok scratch that, we had that laptop set up for a static IP at our last place and forgot to change the IP settings...solved :)
m
l
