No sound after install sound card
i just bought may ati hd5750 graphic card and install it but my sound from desktop haven`t come... i don`t know what to do. i see through the control panel and it show still use the onboard sound . i disable ati HDMI sound and i even see at my bios but don`t have enable sound onboard only azalia codec: auto. someone please help me..im using 450watt psu, intel core2duo 2.4, 3g ddr2 ram. i can play games but without a sound.
5 answers Last reply
More about sound install sound card
  1. Azalia is your onboard audio.
    Have you updated your audio drivers?
    Posting your motherboard info would be helpful.
  2. Did you enable/disable the onboard sound in the BIOS? Are your speakers plugged in? Is the volume set higher than zero...
  3. motherboard gigabyte GA-G31M-S2L . I haven`t update yet..does that needed? i using integrated sound realtek. in BIOS no option for enable onboard sound only Azalia code: auto/ disble-if disable no speaker sign during opening the windows and said no audio output.
    Go to http://www.giga-byte.ca/products/product-page.aspx?pid=2693#dl and download new drivers and bios.
    Azalia should be left auto.
  5. thanks guys . i manage it
Graphics Cards Sound Cards Graphics
