Solved
Hard drive not running at 6Gb/s
Last response: in Storage
Hard drives can be SATA 6Gb/s compatible, not 6Gb/s capable.
No hard drive can spin fast enough to achieve SATA 6Gb/s speeds.
Your drive has a buffer (16MB, or 32MB, or 64MB) which briefly transfers data at 6Gb/ speeds, but that's it.
What's the model of your drive?
What the model of your drive?
It's the WD1002FAEX drive. I have it hooked up to a SATA 6Gb/s port.
Related ressources
Dereck47 said:
Yes, it is. Some faster HDDs (like the Seagate Barracuda) can get up to 210MB/s, which is in the SATA 2 (3Gb/s) speed range.
Thanks for your help. What is the point in 6Gb compatibility if it doesn't come close... I have a lot to learn regarding hard drives.
