Hello,
I have not done the later in a while, it has been years, but I caught up on all the tech in a few weeks. The last pc I built was hardly used for anything like that, (gaming that is), so I want to ask some question on build. This is mainly for gaming and other tasks, just so you know.
I have a friend who wants me to build him a pc. Since I am going to I might as well at the same time build myself one also, I may also have to build more pc's too. He may be on a budget but I do not know what that is, or how much he is willing to spend. I'll try and create one and say he is limited to 700-800 dollars. This does not really matter though, but let me get on with what I want to say.
I looked and noticed the strange activities of ATI and NVIDIA, it is not like I have not gamed on the pc... it is just that I have been out of the loop. I was at a point where I did not simply care about gaming or building pc, or anything, something got me back into it, so where I am! Though I noticed a lot of activity with cards, one thing is for sure, I want to make sure he and I get AMD cards. There is a lot to pick from. I would not even go through this mess if AMD did not release so much of them, I may consider getting one of the 8600 series cards... this all depends though.
Based on my friends build I was thinking of this (yes he is clueless -.-, I might as well make stuff up for him as I go along):
CPU processor:INTEL
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115217
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115218
Mother boards: ASUS
ASUS P7H57DV EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131624&cm_re=ASUS_P7H57D-V_EVO-_-13-131-624-_-Product
ASUS P7H55M Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131623&cm_re=P7H55-M_PRO-_-13-131-623-_-Product
Power Supply Mod/not mod? (I have an issue right here I know what power supplies to get, but here is always the tricky part I want to know what you guys think) I was thinking of a corsair one, which is decent in price and supports sli and Crossfire, even if he or me may not have the option for crossfire or sli atm we may want to in the future, so it is good to be prepared. What PSu's would you recommend? 750 watt 700, 650?
Memory
Corsair or Crucial?
http://www.microcenter.com/single_product_results.phtml?product_id=0345246 (i'll explain why I listed this one)
http://www.microcenter.com/search/search_results.phtml?sku_list=626796+825687+526673+838524+838656+838532+563361+897579+391904+564435+126656+710293+285148+391920+347740+285064+181792+043133+293282+664516+664441+664409+660779
really do not know about the memory just want to make sure.
HDD
500GB-1TB depends this is one I want answers on and if raid or what. I do not now the benefits and if it can be done, or should I say should be done.
VIDEO CARD
6850? 5850/5870? price drops in case there are any?
Misc accessories..
sound card? wireless adapter? fans cooling,
Cool master case?
http://www.amazon.com/Cooler-Master-RC-922M-KKN1-GP-Tower-Black/dp/B0026FCI2U
or are there better cases?
Optical dvd burner drive?
Now here is the main problem
I5 series intel: I5 661 I wanted to get a processor that was decent for the both of us so I picked this. I looked all around and noticed there was not really a need for me to look at the I7's yet. I am not looking for gaming like that, but just so he can play games and I when I get to creating mine.
the ASUS EVO AND PRO both have an integrated graphics/GPU BOOST on them. The Evo also has crossfire, if any of you look at both of those boards you will see a difference between them and the specs they have, and amount of details. I was thinking it would be ok to use the I5 661 with the asus intel specific board for the processor gpu and the on board gpu, along with the potential of using an AMD Graphic card. I was also thinking of adding probably 8gb of ram nothing more than that atm. with Windows 7 64 bit.
Based on what I just explained do you guys see anything wrong, or improvements to be made?
Remember based on my friend he is on a budget but either way, the I5 stays and probably the ASUS M pro, unless you know of other mother boards which have the same type of features.
I want to know every ones advice, and what you all think. I want to see all there is I can add and stuff, or what other accessories I may be missing but have not mentioned.
I'd appreciate any type of advice~!
Thank you for taking your time to read this.
CPU processor:INTEL
Mother boards: ASUS
ASUS P7H57DV EVO
ASUS P7H55M Pro
Memory
Corsair or Crucial?
HDD
VIDEO CARD
Misc accessories..
Cool master case?
