Are my parts compatible?
Oh sorry since it seems like i forgot answer one of your questions.
With the stock cooler and simply raising the Multi, ~3.6Ghz would be a conservative limit, though with some voltage tweaking, decent airflow and low ambients, you should be able to hit 4Ghz. However, Im not sure if the version NCIX sells is a C3 or not, if its a C2, then 3.8Ghz more or less.
Timop
Nope. this is just wasting 30 bucks. SATA 6 is only worthwhile for SSDs down the road.
Even the fastest SATA HDD, the Raptor, barely saturates the avaliable bandwidth of SATA1 (150Mbs)
Timop
