Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Last few parts for a HTPC/Gaming build
Forum Systems : New Build Last few parts for a HTPC/Gaming build
Hey all. I have been slowly researching and purchasing parts for a new amd based htpc/gaming build. I just need some opinions for the last few parts before I start putting it all together.
Approximate Purchase Date: Hopefully within the next month.
Budget Range: So far I am at about $700 invested. All in all I hope to be under $1200 but I'm flexible.
System Usage from Most to Least Important: Gaming, media centre, video encoding on occasion, surfing the internet
Parts Not Required: Motherboard- MSI-890GXM-G65
CPU- AMD Phenom II x4 955 BE
GPU- Sapphire Radeon HD 6870
Blu-ray writer- LG BH10LS30
I also think I have a new WD 500GB caviar green kickin' around.
Don't need monitor, keyboard or mouse, speakers, or OS
Preferred Website(s) for Parts: I would prefer memoryexpress.com but I can use ncix.com, newegg.ca or tigerdirect.ca
Country of Origin: Canada
Parts Preferences: I would prefer corsair for ram and psu but I'm open to suggestion. Since I am using a mATX board I would like to keep the case small. I can sacrifice small for good cable management though.
Overclocking: Probably dabble in it a little bit.
SLI or Crossfire: We'll see about Crossfire. Depends on the case.
Monitor Resolution: 1920x1080
Additional Comments: Ideally I would like a home theater case, but I can handle a small tower if necessary. If I get a case that can fit two of the HD 6870, I will need adequate power.
Since I might do a little overclocking, if I can fit in a H50 that would be great.
I will also be using a Hauppauge HDPVR.
Sorry if this was all pretty specific, but I suppose that is better than vague right?
Thanks in advance for what I'm sure will be a lot of help.
Reply to Ovlazek
You might want to look at these little cases that are H50/Coolit ECO capable
1. Cooler Master Elite 341
2. INWin Dragon Slayer
3. Silverstone SG-03
http://www.rage3d.com/board/showthread.php?t=33961360
4. NZXT Vulcan (via front)
http://www.nzxt.com/forum/showthre [...] -fan-mount
This was my HD 6870CF capable mATX as soon as the HD6k was out :P USD but ya perhaps it could come in useful ^^
http://i137.photobucket.com/albums/q205/batuchka/Untitled-1447.jpg
Thuban as dude was off on some uber geek engineering college thingy LOL
Reply to batuchka
Damn these Radeons are kicking ass on nvidia :)
Reply to Mr Pizza
http://i137.photobucket.com/albums [...] d-1447.jpg
For the Vulcan, the photo on the second page with the evga mb, it looks like he has his gpu on his second PCIex16. That slot on my msi mb is only x8. If I mount my Radeon on the top slot, do you think I will still be able to mount the H50 in the front intake fan?
Reply to Ovlazek
It could get hairy and the H50 cables would run over your GPU but i would say doable but either way in non CF/SLI on a PCIex16 gen 2.0 slot even at x8 you wouldn't suffer deteriorated performance (actually 8/8 vs 16/16 CF/SLI is just a whisker) if that is your concern ^^
Message edited by batuchka on 10-23-2010 at 08:45:02 PM
Reply to batuchka
Timop wrote :
For him, I think the GD04/05 would be more appropriate.
http://www.newegg.ca/Product/Produ [...] 6811163158
Wow what is that expansions slot over the psu for?
Reply to Ovlazek
Its a vent for cooling HDDs apparently.
Reply to Timop
As far as those Silverstone HTPC cases go, I wouldn't be able to mount the rad for an h50 or eco right above the mobo there. Do I have a better air cooling alternative to fit in one of those cases?
Reply to Ovlazek
The Cooler Master GeminiIIS is a guaranteed fit hehe
Reply to batuchka
Do you think the NZXT rogue would be a good choice for a case? It looks like it would have plenty of room for an enclosed water cooler. The cable management would not be as good though right?
Reply to Ovlazek
Rogue has been E.O.L or end of line/life no longer in production for a while now - unless u happen to stumble across a retailer with stocks hehe
Reply to batuchka
Shoot. Yeah as soon as I posted I noticed that as I shopped around. I wonder why it's still on their website. Well since thats out... are there any other cube style cases that would be a good fit?
Reply to Ovlazek
Anyways I also need a psu and memory. Batuchka, that 650W XFX you used in the other build- is that enough power for overclocking and two 6870?
Reply to Ovlazek
If you want Cube case, The Silverstone SG01, SG02 and the Lian-li V531, V532, V354 are good choices.
http://www.newegg.com/Product/Prod [...] 2&Tpk=SG02
http://www.newegg.com/Product/Prod [...] 6&Tpk=SG01
http://www.newegg.com/Product/Prod [...] 6811112221
http://www.newegg.com/Product/Prod [...] 6811112278
http://www.newegg.com/Product/Prod [...] 6811112299
650W is plenty for a 955 + 6870CF, as the whole system uses ~500W under load.
Reply to Timop
Okay. I've decided on a Corsair HX650 as far as psu goes.
The case I am leaning towards an Antec Mini P180. Seems to have plenty of room for an H50 and 6870CF. That and it looks pretty good externally.
Does that sound about right to everyone?
Also still looking for more advice as far as RAM goes. :D
Reply to Ovlazek
The P180 isnt great, but if you like it..
For the Ram, heres a set: http://www.newegg.com/Product/Prod [...] 6820226092
Why do you want a H50 anyways? With a P180, slap a 212+ on it and it a day.
Reply to Timop
Well I will be using it as an htpc as well so I would rather not have a big heatsink and fan making a lot of noise.
Reply to Ovlazek
The H50 is going to be just as loud though, same 120m fan and pump noise.
Reply to Timop
There are 1845 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 1 hour ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
