Need advice for a ~$1000 mid-level gaming system
Approximate Purchase Date: 1st of November
Budget Range: $800-$1200 Before Rebates
System Usage from Most to Least Important: gaming, software dev,internet
Parts Not Required: keyboard, mouse, monitor, speakers, OS (Windows 7 Pro)
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: none
Overclocking: Maybe
SLI or Crossfire: Not necessary
Monitor Resolution: 1920x1080 (HANNS G)
Additional Comments: I used TH’s System Builder Marathon (both $1000 and $2000) as a starting point. I decided on an Intel i5 CPU and picked a case, main HD, PSU, and CD/DVD. Based on these decisions I need help picking a Motherboard, Video Card, CPU Cooler, Memory, and 2nd HD. Below are my base selections and my question selections. Any assistance will be greatly appreciated.
Base Selections:
CPU - Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor BX80605I5750 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
Case - Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
PSU - CORSAIR Professional Series AX750 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139016
Main HD - Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
CD/DVD - LITE-ON 24X DVD Writer Black SATA Model iHAS-324-98 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106334
Selections with Questions:
Motherboards –
ASUS P7H57D-V EVO LGA 1156 Intel H57 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131624
ASUS P7P55D-E LX LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813131634
Video Cards –
MSI N470GTX-M2D12-B GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127501
MSI N480GTX-M2D15-B GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127502
EVGA 012-P3-1470-AR GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
EVGA 015-P3-1480-AR GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130552
CPU Coolers –
Cooler Master Intel Core i5 compatible Hyper TX3 Socket 775/1156/AMD 130W 92mm "heatpipe direct contact" CPU Cooler RR-910-HTX3-G1 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103064
ZEROtherm CORE92 Socket 1156/1366 HDT Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835887023
Memory (6GB) - (Not sure if 6GB is worth the $30-50 more than 4GB)
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel Kit Desktop Memory Model TR3X6G1333C9 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145220
Crucial 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Triple Channel Kit Desktop Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820148247
Memory (4GB) -
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model TW3X4G1333C9A G http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251
Crucial 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model CT2KIT25664BA1339 http://www.newegg.com/Product/Product.aspx?Item=N82E16820148262
2nd Hard Drives -
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
3 answers Last reply
More about need advice 1000 level gaming system
  1. Hi, heres a build that i would recommend for your situation, it falls within your budget at $1006.82 (sorry if i didnt take rebates into account, never come across them before, im australian xD).
    CPU
    The i5-750= $194.99
    Motherboard
    Asus P7P55D-E LX= $134.99
    Case
    Coolermaster HAF 912=$59.99 OR your case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=HAF%20912
    RAM
    G.Skill ripjaws= $94.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=G.Skill_ripjaws-_-20-231-303-_-Product
    Graphics
    Asus GTX 460 TOP 1GB= $199.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121391&cm_re=Asus_GTX_460-_-14-121-391-_-Product
    CPU cooler
    Coolermaster Hyper 212= $29.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=coolermaster%20hyper%20212
    PSU
    Corsair HX 650= $199.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012&Tpk=HX%20650
    HDD
    Samsung SPinpoint F3= $69.99
    (http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&cm_re=spinpoint_F3-_-22-152-185-_-Product)
    The G.Skill RAM is amazing value and awesome performance. The GTX 460 is also an extremely well valued card and plays anygame i have very well, GTX 470's aren't worth it IMO. The CM hyper 212 is a simply awesome cooler which can handle high clocks and at only 30 bucks. The PSU, you don't need a 750, the HX650 is a quality PSU that will even work perfect if you do decide to SLi or do some OC. The Spinpoint also seems better value and is a favourite at these forums.
    I know that you have stated that SLi is not necessary but a second GTX 460 would give you stellar game performance, a 460 SLi can surpass a single GTX 480 and its cheaper too, but this is just and idea :), you choice (it would bring the price up to $1206.81)
    I hope this has been of some help to you :) shout if you need anything else.
  2. Correction: The HX 650 is $119.99, not 199.99 my bad.
New Build Systems Product
