I was just hoping I could ask some advice.
I bought a nzxt 140mm fan for the the replacement top to my a05n, and was having some problems with the screws.
The screws (that came with both the fan and the replacement top) don't seem to screw all the way down. I am going to strip them if I try any harder to screw them the rest of the way in.
Should I be getting some rubber washers to put in between the fan and the top, or what else can I do.
