Hi All,
I have just bought myself a 2600k setup and am giving my old Q9550 to my parents.
My Mom uses outlook, puzzles and browsing, my dad uses matlab and c and fortran compilers for his work.
All in all not very CPU load intensive requirements. The main requirements for my parents are:
1) Quiet
2) Reliable
3) Quietly Reliable
Now when I bought the CPU I slapped on an Orb 2 cooler and left it as is, the box has never been overclocked.
I have now dusted, cleaned, reformatted the PC and am ready to give it over. Before I did that I decided to run a CPU benchmark to see if all is well. All does not seem well however.
Using Prime 95 with 4 threads and SpeedFan 4.42 for readings:
Idle:
CPU 39-40C, 4 Cores Avg 37-41C
30 Minutes of Prime 95:
CPU 68-71C, 4 Cores Avg 64-72C
Ambient temp is around 27C now.
Case open or closed makes about 2-3C difference.
CPU fan @1300RPM to 1900RPM - about 4-5C difference (HUGE noise difference though)
So my best temps at load with the loudest settings still sit at over 64C
What can I do?
My only thought is reseat the HS (replace the 2yo thermal paste).
Will that help? Are there any other suggestions ideas?
Thanks
Now for my problem:
1) Quiet
2) Reliable
3) Quietly Reliable
Idle:
What can I do?
Thanks
Now for my problem:
