XFX ATI HD 5770 RADEON / 32BIT VS 64BIT
RUNNING XFX 5770 BETTER ON 32BIT vs 64BIT, ALSO WOULD IT BE BETTER TO RUN WINDOWS XP vs WINDOWS 7
please advise,
thnaks.
6 answers Last reply
More about 5770 radeon 32bit 64bit
  1. 32 or 64bit OS has nothing to do with graphics penformance, if you have at least 4gb of ram 64bit will be better.
    Use windows 7
  2. Use 64 bit WIn7, with a 1GB 5770, you'll be limited to 2GB of RAM for an single app on 32-bit.
  3. with windows xp, u wont experience any direct x10 & direct x11 effects. ur hd 5770 has the both effects if ur using windows 7. So, why not windows 7? 64bit for ram more than 4gb.
    Use windows 7
    Great, thank you very much.
    Thanks for the info, this helps me a lot.
    Thank you very much.
    Thanks a lot, this was a great help.
Radeon ATI HD Windows XP Graphics
