So my computer is in a room with the monitor that I regularly use(Acer 22" LCD), and I recently moved a 32" Sony Bravia LCD into the room. Now when no one is using the Bravia, I would like to use that as my display. The thing is that the monitor's resolution is 1680x1050, and the Bravia is a 720p HDTV. I don't want to have to change my desktop resolution every time that I switch between them, so I was wondering if there is a way in CCC that I can save settings for each display. I was also wondering if I can just leave both plugged into my 4870 and just switch between them in CCC. And I DO NOT want to display stuff on both at the same time, just to make that clear. I should probably mention that my PC is connected to the monitor via DVI and my PC is connected to the Bravia via a DVI to HDMI cable. Any feedback is appreciated.
