Im buying the coolermaster haf x case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119225
and extra 200mm fan for the side (current side fan is going to be moved to the top)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103072
a thermaltake frio cpu cooler which i plan to set up in a push pull configuration (2 fans)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835106150
and finally im buying an ASUS P8P67 PRO mobo
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131682
this is my first time building a pc so sorry if some of these questions are common sense/obvious but I have a 5 case fans (230 front, 200 side, 2x200 tops, 140 rear) and 2x120mm cpu fans for my thermaltake frio, a total of 7 fans. But looking on ASUS's website, there are only 4 places on the mobo to connect my fans to
http://usa.asus.com/product.aspx?P_ID=HMMvTCuBcZLfu2YL&templete=2
"1 x CPU Fan connector(s) (4-pin)
2 x Chassis Fan connector(s) (1 x 4-pin; 1 x 3-pin)
1 x Power Fan connector(s) (3-pin)"
my question is, what happens to my other fans? Surely asus would know that most people would have more than 4 fans! Do I plug in my extra fans directly into my PSU? do i ditch them?
My psu is a corsair 950W TX PSU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139013
Could someone please tell me what to do here?
P.S. heres my full build if you need it:
http://secure.newegg.ca/WishList/PublicWishDetail.aspx?WishListNumber=13192571
Thanks a bunch!
Thanks a bunch!
