Will this build work?
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM Microsoft
Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
AMD Phenom II X6 1055T Thuban 2.8GHz Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX
Thermaltake Element G VL10001W2Z Black ATX Mid Tower Computer Case
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ...
4gigs of Gskill RAM
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Will all that be compatible? And, for the task I am using the build for, I will be using 100% CPU for prolonged periods of time (possibly overclocking the CPU from 2.8 to 3.2 or 3.4). Will I need liquid cooling or will the stock fan be fine? If I need liquid cooling, would a corsair h50 fit in this build?
Thanks for all the help, really appreciated.
4 answers Last reply
More about will build work
  1. 1. Go for an entry level 800 series mobo rather than a 700 series one : a BIOS update is mandatory with the latter
    2. IGP + Thuban: 700W way overkill - hit a 450-550w 80+
    3. F3 1TB? In fact a PSU + F3 1TB combo
    4. Such light OC has been done on stock HSF but dun H50 not worth it - hit a decent air cooler like CM 212+, Mugen2/Yasya
  2. Alright thanks very much. Saved me a lot of $ :)
    One question, could I buy the haf 922 incase I want to upgrade some time in the future and have enough room for all the upgrading? Would this setup work fine in the haf922 or do I really need to stick with the suggested case?
  3. Any case as long as being able to house mATX mobos would be fine ^^ U are welcomed ^^
New Build Systems Product
