I'm trying to build my first gaming computer and have just today learned only some of the terms and only then in online pictures, forums, and other articles. Therefore i'm completely new at all of this. Anyway i found all the components i think i want to use and they add up to $1600 so i want to know if they work together or should be changed in any way. Here they are:
Cooler Master HAF Full Tower
http://www.tigerdirect.com/applicat...ffiliateID=iFudSkud_Rc-8RMnK2YCZBEUk0IKgEoXew
Intel Core i7 860
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4959972&Sku=I69-0860
Asus P6T Mobo
http://www.tigerdirect.com/applicat...ffiliateID=iFudSkud_Rc-YOTpEtsbZd0bw4wufpi.hw
Western Digital Caviar Black 1TB Hard Drive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076939&CatId=8
Diamon Radeon HD 5850 Video Card
http://www.tigerdirect.com/applicat...ffiliateID=iFudSkud_Rc-CfGHkOxZF2lnr5uxSMvJLw
Ultra X4 750-Watt power supply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4558896&Sku=U12-40504
Asus Dvd Burner
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6078414&Sku=A455-5022
OCZ Platinum Tri Channel 6GB DDR3 Memory
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4282840&CatId=4327
And then i'd be using Windows 7 Home premium 64Bit. Unless i should do the 32bit. the only difference i know is the 64 handles more data better.. or something of that sort.
Anyway thanks so much for any help in this regard!
Intel Core i7 860
Asus P6T Mobo
Asus Dvd Burner
