Help with this build please.
Hello everyone, I'm looking to build a gaming computer for around 750 dollars. This will be my first build so I am looking for a bit of advice. Here are the parts:
LG DVD Burner - Bulk Black SATA Model GH24NS50 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136177 $17
SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908 $180
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9
combo with
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.514332 $116.98
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
combo with
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.514469 $115
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
combo with
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.526569 $235
Windows 7 OS $100
=773 with shipping
+45 dollars in mail in rebates cards
=728
Now I am wondering if there is anyway to stay around 750 while upgrading to a 6870 card and keeping a motherboard brand that I have heard is reliable(Gigabyte and Asus). Thanks in advances for any answers or comments.
9 answers Last reply
More about help build please
  1. Doubtful, looks like a good build as-is.
  2. Proxi, how does this CPU compare performance wise with the build you're helping me with? There aren't a lot of differences except the processor is totally different...
  3. Quote:
    $727 with just the one HD 6870 1st hehe
    The i5-760 is a stronger processor. The Phenom II X4 955 and 965, 970 are not too far behind it. If you would like to trim down the budget it's a good way to go.
    There are more differences in the build than you think though.
    -No USB 3, SATA3
    -550W PSU instead of 750W
    -CL9 RAM instead of CL 7
  5. How is this motherboard compared to the one in the original build?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131647
  6. Better in that it has newer features. Worse in that it is not a crossfire board. If you aren't going to run two video cards it's the better choice.
  7. Hello, proximon is right the mother board has a newer features but it's not a crossfire board. So i did a little research. In the first meseage you found a deal: Processor: amd phenom ii x4 955 BE and a mobo for $235.
    Well i found the same processor for $140 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808&cm_re=amd_phenom_ii_x4_955-_-19-103-808-_-Product
    and a way better mobo that has new features and also supports crossfire: MSI 890GXM-G65 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130269R for $96
    Together: $236
    I think you should change the processor and mobo u showed for the ones i found, with the rest of the parts you showed it shall be a good build.
  8. Thanks for all the answers and advice,one more question.
    Would it be worth changing the sapphire 6850 to the asus 6850?
    This one-
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121399&cm_re=6850-_-14-121-399-_-Product
    I have read it has more performance and it is the same price
  9. Well about the 6850 from sapphire you get Core Clock: 775MHz, and the asus is a bit overclocked to Core Clock: 790MHz. So yes for the same prize you get a BIT more performace. But for your advise 6850 is $200 and 6870 is $230, so if i would be you i would go for the 6870.
    Also before you choose the best answer and close this thread tell us what system you decided to go for and why.. thanks
Homebuilt Build Systems Product
