Dell 610 laptop screen problems
Anonymous
a b U Graphics card
September 7, 2010 1:48:00 AM
Hello, my screen is black with just the cursor blinking top right. Twice i turned off and removed battery and it worked; twice it did not. What's going on?
a c 1363 U Graphics card
September 7, 2010 3:34:44 AM
It is possible that you have a corrupt OS (windows) install. Repair install would fix that. If you can turn it on have system tools check for errors and do a defrag of the hdd.
m
l
a c 189 U Graphics card
September 7, 2010 7:39:16 AM
Can you see POST screen? or BIOS screen?
Agree with rolli, try re-install your OS...
m
l
