Sign-in / Sign-up
HELP vertex 4 ssd black screen problem
  • SSD
  • Vertex
  • Storage
Last response: in Storage
February 4, 2013 4:26:03 AM
Hello , ok I just bought the vertex 4 ssd 512 drive and its installed, so I install windows 7 64bit ultimate on it and it works fine but then when I do the first windows update it restarts and I see the windows logo , then it goes black and just hangs and dose nothing. I have a rampage 3 board, 980x i7 , 5970 4gb video card , I also have a raptor hdd installed as my back up . I have no idea how to fix this . please if anyone at all can help me I would be greatful. thank you
More about : vertex ssd black screen problem
a c 590 G Storage
February 4, 2013 4:41:46 AM
Sounds like your problem might be video card drivers related. Did you already install your video card drivers when your problem started? If so boot into Safe Mode and uninstall your drivers. Then reboot into Windows and let Windows install its own default video drivers.
Then try Windows update again and see what happens.
m
l
February 4, 2013 4:46:29 AM
no its a fresh windows install
m
l
a c 590 G Storage
February 4, 2013 4:59:47 AM
Is your motherboard on its latest BIOS version? Is your Vertex 4 on firmware version 1.5.1?
m
l
February 4, 2013 5:05:03 AM
how do I check firmware on the vertex?
m
l
February 4, 2013 5:10:47 AM
I cant load windows I hangs right after the windows logo then goes to a black screen
m
l
a c 590 G Storage
February 4, 2013 5:19:55 AM
Press & hold the F8 key right before the Windows logo appears to go into safe mode.
m
l
February 4, 2013 5:25:30 AM
alright tring now, this is weird why its doing this , my pc was fine before I added this ssd.
m
l
February 4, 2013 5:34:59 AM
I cant get it to work
m
l
a c 590 G Storage
February 4, 2013 5:44:33 AM
Does your raptor HDD still have Windows installed on it?
m
l
February 4, 2013 5:44:48 AM
got it its at firmware 1.5, no I deleted everything off the drive and reformatted it
m
l
a c 590 G Storage
February 4, 2013 5:54:12 AM
I would suggest that you start over. Update the drive version 1.5.1 and then Secure Erase the drive to restore it to fresh-out-of-the-box condition.
After the Secure Erase do another fresh Windows install.
Connect the drive to one of the Intel SATA 2 (3Gb/s) ports in AHCI mode.
After you successfully install Windows and install all of the updates you can then connect it to one of the Marvell SATA 3 (6Gb/s) ports in AHCI mode.
m
l
February 4, 2013 6:00:52 AM
oh ok , can you help me on updating it , I downloaded the ocz toolbox but its giving me an error when trying to download the update, also how do you put it in ahci mode? its weird I installed windows 7 on the ssd and im on the desktop now , but if I install windows updates that's when it hangs after the windows logo on restart
m
l
February 4, 2013 6:09:40 AM
ok just changed it to ahci mode it was on ide
m
l
a c 590 G Storage
February 4, 2013 6:13:54 AM
You change SATA modes in your motherboards BIOS. You'll have to check your manual to see how to do it.
Your SSD has to be in AHCI mode in order to use the Toolbox.
If you don't want to start over then see if you can install Windows updates while in Safe Mode. Your system might not hang if you install in Safe Mode.
m
l
February 4, 2013 11:09:19 AM
have you heard why this happens, 400. for a ssd and I should have stayed with my raptor hdd.
m
l
February 4, 2013 11:24:58 AM
it seems its working now fingers crossed once I changed it from ide to AHCI mode, Ill report back once I get things installed. thank you
m
l
February 4, 2013 11:37:36 AM
on my rampge 3 mother board in the bios it says sata configuration its on enhanced then configure sata as is on ide should that be on ahci also? or left on ide? thanks
m
l
a c 590 G Storage
February 4, 2013 12:37:36 PM
SATA ports can have 3 settings (modes): IDE, AHCI, & RAID. All SSDs need to be in AHCI mode for best performance. Being in IDE mode is probably why you were having your problems.
When changing from IDE to AHCI after Windows installation you need to edit your Windows Registry file.
Here's a link on how to edit the Registry file: http://www.ocztechnologyforum.com/forum/content.php?286...
Yes, "Configure SATA as" should be set to AHCI.
m
l
February 4, 2013 12:52:09 PM
oh ok will try all that then report back , one more question another reason why im reboot my os is because I use avg and something happened that it woulnt pdate for some reason, so they told me I have to reboot and install Microsoft net framewok 1-4 in that order but Im installing windows 7 64bit ultimate is there a certain way I have to do this? thanks
m
l
a c 590 G Storage
February 4, 2013 1:00:03 PM
After you install each version reboot your system before you install the next version.
m
l
February 4, 2013 2:28:24 PM
how many is there and do I have to do them in order? I know theres 1.0 , 1.1 , 2 , 3.5, nd 4 .
m
l
February 4, 2013 2:38:17 PM
also looks like its still giving me the hang time after the windows logo, Ive rebooted this pc 5 times in the last 24 hours.
m
l
February 4, 2013 2:57:01 PM
ok I think I got it now to work , so how would I do this mirosoft netframe work think so I have all of them installed , I have older programs that need the older frameworks so theu told m to install them all, but I have to be careful and I tried theres to many diff ones not sure what ones to install for windows 7 64bit os , if you can help me out with links on them thatll help me out a lot , thanks
m
l
a c 590 G Storage
February 4, 2013 4:02:22 PM
While installing Microsoft .NET Framework versions 1,2,3, & 4 won't hurt, it seems like a waste of time.
I would just install version 4, which would have everything 1,2, & 3 has.
Actually the latest version is 4.5 so I would install that.
Here's the link for the 64-bit version of Windows 7: http://www.microsoft.com/en-us/download/details.aspx?id...
You need to have Windows Service Pack 1 installed first so make sure your Windows updates are up-to-date before you proceed.
m
l
February 4, 2013 6:28:07 PM
k got all that now, now my raptor hdd drive isn't showing , it shows in bios but not in my computer.. not sure why
m
l
a c 590 G Storage
February 4, 2013 8:38:36 PM
Go into Windows Disk Management, initialize the drive, assign it a drive letter, and Quick format it. It will then be ready to use.
m
l
February 5, 2013 1:06:50 AM
got it thank you very much for your help
m
l
