My mouse seems to have got extra sensitive of late. If you hold down the button after clicking, it will more or less perform a double click.
Problems :-
-Almost impossible to drag and select text [Since another click deselects it]
-Sometimes leads to multiple windows closing if the 'x's are aligned, as in maximized
-Stuff like that
It's a hardware problem, I'm sure of that, since it doesn't happen sometime. The frequency is also reduced if I remove the mouse cover and use the actual button to click, although the button seems to have got loose [compared to the right click button, which is comparatively firm].
Should I check the wiring ? Sometime back, the wiring had got damaged [One of the four wires somehow broke] and I had joined it manually.
Or is it time to get a new one ? It's a 7 year old mouse, got it with my Compaq Presario SR1105IL. Laser, wired. Using XP.
Any way to prolong its life by a few months ? Reason being I'm getting a brand new PC in a few months anyway.
Problems :-
-Stuff like that
