Solved
Is my power supply enough?
Hi, I bought a new computer and was wondering if my power supply would be enough because I changed the video card on the computer. The model name for the computer is hpe-421f (HP onboard) and I changed the video card which was in the computer to a GTX-460. The current power supply I use is a Corsair 550W power supply. Thanks in advance and if you guys need to know anything else about the computer please tell me. TY.
6 answers Last reply Best Answer
More about power supply enough
  1. 550w is sufficient, I've just looked at the specifications of the HPE-421F. But make sure you have enough amperes (peak wattage divided by 12 as that is how many amperes will be needed on the +12V rail(s)).
  2. Best answer
    One of my systems has an OC'd Q9550, 4 GB RAM, a GTX260 - a card with similar power requirements to yours, a Gigabyte EP45-UD3P motherboard, 3 hard drives and an optical, and a Soundblaster card all powered by a Corsair 750TX.
    Running 3 instances of Prime95 to load the CPU and 3DMark06 to load the GPU, it pulls 375 watts from the wall as measured by my Kill-a-Watt meter. Figuring 80% efficiency, the system pulls 300 watts from the PSU.
    So, yes, a 550VX is certainly much more than adequate. With a full system load, it will be running around 60% of capacity.
  3. It's fine. If you are not running too many additional cards or hard drives then it is more than fine. Even the GTX470 just recommends a 550w PSU for a single card configuration.
  4. More than enough.
  5. thank you so much for your replies :)
  6. Best answer selected by cybercafe.
Power Supplies Graphics Cards Computers Components
