Hello,
I have an HP Pavilion DV4. The hard drive controller is toast (so HP tells me) I got it cheap from a friend of a friend. I have a few laptops and was going to use this for an internet spare like installing a small cloud OS like JoliCloud. I WILL NOT buy a new Motherboard... So what other options do I have for installing a hard drive? I have heard yes and no on using the extra mpcie to put an ssd drive there, but even if that works will it boot? I know I can use an external hard drive but I don't want a drive hanging off this computer I want to actually put a drive inside it... there is room in the old hard drive area and like I said I got an extra mpcie slot also I have the mini pcmcia slot or a sata port on the side or maybe the DVD rom slot... What can anyone think of????? It needs to be able to boot. INTERNAL HARD DISK DOES NOT EXIST OR WORK... Thank you
*Email removed to save you from spam*
