Solved
Advice on Graphics Design (CS4)/Multi-Task Build
Approximate Purchase Date: within 2 weeks (can be swayed to wait a month or so if it its worth the wait)
Budget Range: approx $1000
System Usage from Most to Least Important: graphics design using CS4/CS5 Master Collection suite, video editing, lots of multitasking, email, internet, design. Need to have multiple CS apps open at once interchanging between them for magazine and book layouts
Parts Not Required: keyboard/mouse (logitech cordless wave), monitor (samsung 22" syncmaster t220), 1TB HD (WD green sata 3.5" WD10EADS--brand new in box)
Preferred Website(s) for Parts: doesn't matter, using newegg.ca (feel free to suggest best)
Country of Origin: Canada
Parts Preferences: Intel CPU, Asus mobo
Overclocking: No idea
SLI or Crossfire: No idea
Monitor Resolution: prefer the best...1920x1200. I plan to have a dual monitor system. will purchase other monitor down the road (maybe during boxing day bonanzas). This way one is dedicated for design the other for administrative (email, internet, etc)
Additional Comments: Looking for quiet PC. Some of the parts here maybe overkill (e.g. 8GB RAM), but feel free to let me know. I know its not a gamer, but realize that some of these photoshop or indesign or illustrator files get very large. When you have three of these running at the same time, plus email, plus internet, I didnt want to take a risk so I went with lots of RAM. Again, I am open for suggestion from you the experts on any of these parts, including CPU. Also, since I will be using two monitors, should I have two video cards?
Here is the build I was thinking of:
Qty. Product Description Savings Total Price
1 Antec Three Hundred Black Computer Case -$10.00 Instant
Item #:N82E16811129042 59.99
1 CORSAIR CMPSU-650TX 650W Compatible with Core i7 Power Supply -$20.00 Instant
Item #:N82E16817139005 $20.00 USD Mail-in Rebate 99.99
1 SAPPHIRE Radeon HD 5770 100283-3L Video Card $15.00 Mail-in Rebate Card 144.99
1 COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 120mm sleeve CPU Cooler -$30.00 Instant
Item #:N82E16835103065 29.99
1 Intel Core i5-750 2.66GHz LGA 1156 95W Quad-Core Processor 208.99
Item #:N82E16819115215
1 Western Digital Caviar Blue 640GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive 69.99
Item #:N82E16822136218
1 Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate -$10.00 Instant
Item #:N82E16820223103 9.99
1 ASUS 24X DVD Burner - Bulk Black SATA Model DRW-24B1ST/BLK/B/AS 24.99
Item #:N82E16827135204
1 Arctic Silver 5 Thermal Compound 9.99
Item #:N82E16835100007
1 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory 179.99
Item #:N82E16820231314
2 Scythe S-FLEX SFF21E Case Fan 20.98
Item #:N82E16835185005
1 ASUS P7P55D-E Pro ATX Intel Motherboard -$10.00 Instant
Item #:N82E16813131621 187.99
1 LG Black 10X Blu-ray Burner - Bulk SATA WH10LS30 LightScribe Support 129.99
Item #:N82E16827136181
Subtotal 1177.86
Shipping 28.18
Tax (GST/HST) 156.78
Grand Total 1362.82
8 answers Last reply Best Answer
More about advice graphics design multi task build
  1. friendly bump! :)
  2. For your usage, IMO the AMD's 6-Core CPUs would better suit...
    CPU - 1055T + OCZ Vertex 2 60GB
    http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.528044
    Mobo + OS
    Gigabyte 880G + Win 7 - FOr your usage, I dont see the need for an external graphics card...
    http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.533865
    Mushkin 8GB DDR3
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16820226095
    Antec 300 Illusion
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129066
    Corsair 400CX - Can handle even HD 5750 and such so it would suffice IMO...
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139008
    HDD - As you have a 1TB for data and a SSD, I dont think you would need it...
    DVD
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106289
    Total - ~$811 Including Shipping + ~$106 Tax = ~$917
    If you want a vidoe card, then I would suggest this -
    EVGA GTS 450 1GB - The Nvidia cards play well with CAD programs compared to the ATI cards
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130572
    Total with the graphics card - ~$1058 Including shipping and tax I guess + you have about USD 55 in rebates...
  3. Best answer
    Or if you want an even more powerful setup, then change the CPU, mobo, RAM to these from the above build...
    i7 950 + ASUS X58
    http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.526547
    12GB DDR3
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16820226096
    SSD + OS
    Rest same as above -
    Total - ~$1164 before shipping, taxes...
  4. Thanks gkay09 for your valuable input. I will check out your suggestions and let you know how it goes. Thanks again.
  5. Unfortunately all your links take be to the home page :(
  6. ^ Right-click and open in new tab...that should fix it...
  7. Thanks. Tried that but it wasnt worked. Open in new window did. Strange.
    Putting together different packages. Will post update. Unfortunately the intel combo is no longer avail!
  8. Best answer selected by phife99.
New Build Systems
