Ok. I was installing a Cooler Master Hyper TX3 today, and after I had plugged in everything after installing it, I tried booting it up, but every time I pressed the power button, the whole computer seemed to short circuit (no hard drive spin up, no bios boot, nothing, and then it all turned off with a small noise). I know there was power, because my PSU LED was lit up, but after the short, everything was turned off. After taking everything out and putting it back in, I tried booting up. Everything started running, my hard drives spun up, and then, a capacitor right next to my 4-pin CPU power connector exploded and threw up smoke all over my computer. Obviously now, my CPU isn't getting power, and it won't boot up. However, if I unplug the 4 pin CPU power cord, the hard drives spin up and everything when I boot it. I already have a new motherboard on the way, but I want to make sure this doesn't happen again to my new motherboard.
Note: I did drop my CPU before this happened, bent 2 pins slightly, which I bent back into place. Maybe something to do with it?
