Dual Monitor Gaming! Help
  • Nvidia
  • Dual Monitors
  • Monitors
  • Graphics
September 9, 2010 5:19:39 AM
Hi Guys,
I have 2x 19" Widescreen Monitors and i have spent almost all day trying to get games to work on them. Currently i have Ultramon & Display Fusion installed and although they help alot with the desktop dont do a thing in game. So basically what i am asking for is a program that tricks windows into thinking that my 2 monitors are 1 big one. I have tried Nvidia's Control panel and it didnt help. And yes i know that it will be split right down the middle, i will be getting 3 in the future anyway.
Any Help would be fantastic guys :D
More about : dual monitor gaming
a c 173 Î Nvidia
a b C Monitor
September 9, 2010 3:17:13 PM
What cards do you have?
m
l
September 10, 2010 5:51:49 AM
I have a 9600gt at the moment, but will be upgrading soon.
m
l
a c 173 Î Nvidia
a b C Monitor
September 10, 2010 2:49:04 PM
You should be able to extend your desktop across two monitors but it won't work for gaming, to get multi monitor support for gaming you're going to need at least two GTX260's.
m
l
September 10, 2010 3:27:12 PM
Don't 2 moniter's count as 1 big resoltuion? Is that why you get those crazy numbers when looking at it card it says max resolution like 2xxx by something?
m
l
a c 173 Î Nvidia
a b C Monitor
September 10, 2010 3:44:59 PM
Only if you're using Surround Vision or Eyefinity.
25 x 16 is the high end resolution that many 30" and bigger monitors can achieve.
m
l
a b Î Nvidia
a b C Monitor
September 10, 2010 4:23:14 PM
It may work but performance is something else just give it a shot but a 9600gt isn't much these days.
m
l
September 11, 2010 5:58:50 AM
You guys still havent said the program i need for this.
m
l
September 11, 2010 7:22:10 AM
That's because there is none.
m
l
September 11, 2010 7:38:26 AM
so there is no way i can run games on both monitors? And i know about the video cards i am getting new ones soon.
m
l
September 11, 2010 8:45:25 AM
You can, but all important info such as HUDs, crosshairs will be split in to by the monitor bezels.
Hence, a three monitor setup.
m
l
September 11, 2010 9:02:02 AM
I know, I will be getting a third for christmas or w/e.
Does anyone Know how to get SoftTH working for 2 monitors?
m
l
