Power supply coolmax model vl-600b compatibility emachine et1331g
Last response: in Components
January 23, 2011 9:41:56 AM
Hello, sry bout the blank post i just need to know if the power supply i bought (the one in the heading) is compatible with the comp. (also in the heading. Thank You
a b ) Power supply
January 23, 2011 10:14:54 AM
Compatable =YES
Suggested =NO
Coolmax power supplys are near the bottom of the list for quality. If you put in the Emachine without any other upgrades you will probably be fine. If you are putting in a power hungry graphics card, I would look for something better.
m
l
a c 712 ) Power supply
January 23, 2011 1:40:04 PM
^+1
m
l
a b ) Power supply
January 23, 2011 2:41:43 PM
the VL in the model number stands for Very Lame.
m
l
