However, I wouldnt recommend rushing into using it with UT2004. I'm using it
and there are some strange stutters / slow-downs.... I've got a radeon 9800
with the catalyst 4.7 drivers installed. Someone I know has also seen a
similar affect using it with an NVidia card.
I suspect the upgrade enables stuff in UT that's been there all along ---
this may be the cause. There could be a tweak to fix the problem if only I
knew what to tweak.
Is anyone else getting problems like this? Anyone know a solution?
Archived from groups: alt.games.unreal.tournament2003 (More info?)
Best to stick to "if its not broken,dont fix it" then
"flak monkey" <p-a-u-l-s-p-a-m@which.net> wrote in message
news:eO2dncWrsJnbB5fcRVn-hg@nildram.net...
> Hi folks - DirectX9.0c is now available from Microsoft here:
http://www.microsoft.com/downloads [...] laylang=en >
it
9800
> knew what to tweak.
> Paul
Not trying to sound like a complete ass, but your best solution in a
situation like this is a good backup. It's fairly well known that
DirectX cannot be uninstalled... at least it's not supported, so
before making a plunge like that you should image your hard drive so
you can recover gracefully when/if it borks your system.
it
9800
> knew what to tweak.
> Paul
did you upgrade your video drivers at the same time? I would more likely
blame the catalyst drivers since 4.6 and 4.7 seem to be causing quite a few
problems for some people with games. I haven't had any problems on my 9700
pro system with cat 3.9 or my nvidia system with dx9.0C.
