Usb-Zip Booting problem
prohank
Hi guys,
I have Windows XP and Ubuntu 12.04 installed on my system on separate partitions.
I burnt an image file onto my pendrive and booted it at startup but it gives a beep sound from the CPU and resets my BIOS config.
Also after the booting I can only see the main screen of the program booted,nothing can be selected,no keys work.
Keyboard or Mouse don't work though they work fine on the Grub Menu(Screen for selecting Ubuntu/Windows).
I have tried it with 3-4 images on couple of PDs but there seems to be an internal problem.
Any Suggestions/advises will be really very helpful.
Thank you very much.
prohank
Unfortunately my Ubuntu is also not working.
I ran an update in it and getting an error while booting it.
"Your screen, graphics card, and input device settings could not be detected correctly. You will need to configure these yourself."
asked in the ubuntu forums but nobody as of now know the answer to the problem.
So I want to reinstall Ubuntu using my PD.but its having problem too :(
