Hello, I am having strange issues with a newly bought Verbatim 2SSD128 (47478). The disk works as expected from its class when connected as a secondary drive (consistent reads and writes in the ~200MB/s region, slightly under), but basically holds to a still when system is booted from it (down to 10MB/s or even less then that on few occasions).
I have tried on two very different machines (a HP HDX18 laptop with SATA2 and a modern i7 desktop with Gigabyte motherboard with SATA3), the results are the same. Its not the machines as they both work absolutely fine from OCZ drives. I thought it must be a faulty drive so went back to the shop and got it replaced with a new one (confirmed with S.M.A.R.T. operating hours) but the problem persists.
HD Tune shows its speed as almost a flat line with ~244 write and ~200 read when the drive is not being used as system drive, but as soon as the drive is booted from it shows a bumpy line of 0.6 MB/s (!!!!) with occasional peaks of ~10MB/s (!!!).
I am out of ideas for tests to run on it, reinstalled the system two times now, and even made a 1:1 copy of a system that works absolutely smooth of an Agility drive - same results.
I also run ATTO benchmarks on it and results were consistent with above - absolutely fine when run as a secondary drive and wierd irregular shaped graph never going above 15-20MB/s when a bare system is booted from it (with no other system activity)
I may give it a go on a mac just to rule out that its windows 7 fault, in the meantime suggestions appreciated.
thanks
thanks
