On Real Temp my temperature is 21c 22c and my distance to TJ max is 85 82; what does this means? Is my CPU safe at these levels? I do plan on mounting a 200mm fan on the top of the case for additional air flow.
So far, this is what I have:
Case: Cooler Master Haf 912.
1x120 on the side panel, 2x120 in the Front and "Soon" 1x200mm fan on the top
Motherboard: MSI P55m-GD41
Liquid Cooling: CoolIT SYSTEMS ECO-R120 Advanced Liquid Cooling. Two Fans mounted for push and pull configuration.
CPU: Core i7 875K Unlocked 2.93GHz
Video Cards: 2x HIS Radeon HD 4670 1GB 128-bit
Memory: G.SKILL Ripjaws 16GB's
Hard Drive: 1Terra bit
Optical Drive: 3x DVD burners and 1x Bluray burner.
