Ok, I finished my new build but later found that the front panel jack isn't working.
Mobo: ASROCK 880GM-LE with 5.1 CH HD Audio (ALC662 Audio Codec)
I installed all the latest drivers but I think it's a BIOS problem. I connected the HD AUDIO jack from my case to the correct slot on the MOBO but upon entering the BIOS, front panel hd audio is not enabled and it is not possible to enable it.
Any suggestions?
Any suggestions?
