Fan Problem
Hi guys, i'm new into the pc world and i want to buy a fan for my case because its running quite hot. (Cooler Master R4-L2R-20AR-R1 R4 Series Case Fan - 120mm) just wondering if it does come with a 3-pin to molex connector. And i see that its 3-pin to a male and female molex. Does that mean i have to connect both molex's? or just 1?
2 answers Last reply
More about problem
  1. It comes with the adapter. You only need to connect one, the other one is only if you want to splice into another existing connection.
  2. ahh, thanks mate :P
Homebuilt Cooler Master Cases Fan Systems
