APPROXIMATE PURCHASE DATE: 1 or 2 next day
BUDGET RANGE: 650-700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Programming
PARTS NOT REQUIRED: Cassing, Monitor
PARTS PREFERENCES: AMD X6 1090T
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1280x800
ADDITIONAL COMMENTS: if $750 is not possible, how much should I spend on this
I Currently have a combination like this:
- AMD Phenom II X6 1090T Black Edition 3.2GHz Socket AM3 125W Six-Core
- ASUS M4A87TD AM3 AMD 870 SATA 6Gb/s USB 3.0 AMD Motherboard
- SAPPHIRE Vapor-X 100283VX-2L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1
- A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 1333G
- SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Internal Hard Drive
- SAMSUNG Black 22X DVD-R 6X 48X CD-R 2MB Cache SATA CD/DVD Burner
- OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 Active PFC Power Supply
Can you suggest me a better choise please, i really need your suggest as im new in this
OVERCLOCKING: Maybe
