this is the build I'm going for..is it any good? will all the hardware cooperate with one another? should I change some things? yes this is my first time trying to build a computer, any advice would be appreciated
motherboard: ASUS M4A89GTD PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131631R
graphic card: gtx 460
the reason I'm going for the gtx 460 instead of Ati newer 6000 series models because of the software I'm using sometimes got problems running on an ati card..I don't know why though.. and yes I decided to not sli it simply because the motherboard only supports cross fire.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333
psu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
computer case:
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
ram:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
and lastly..
cpu: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
and
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.374195
this is the build I'm going for..will it work? should I change some stuff? would it be able to run mass effect 2 and bioshock 2 on high settings?
psu:
computer case:
ram:
and lastly..
and
