On October 23 I assembled my first gaming computer (I'll post the specs below), after getting help on what to buy here. I put the parts together, installed the OS and drivers and everything ran great. I could run Crysis at high settings very smoothly at 1280x1024, and I went on to purchase TF2 + Gmod, which also ran wonderfully. However, I now seem to have a bit of an issue. Occasionally, when playing games my computer will completely lock up (except for music, which continues). When this happens (again, it's pretty random as to exactly when it happens), lots of bars of mostly-solid color (there is a bit of a gradient to the side of each bar) run the length of my screen.
The part that concerns me the most is that this did not initially occur within the first few days of me building the computer. The Crysis demo ran great from start to finish, but now I can't play for more than about thirty seconds. I had attributed this to memory, since I'm usually sitting at about 30% load on idle, but I cannot be certain.
Another issue is that I did get the BSoD once, but the message flashed so quick that I couldn't read the error, and my computer successfully rebooted. Another time I got a message that my graphics driver stopped responding after my screen turned white for a few seconds while using Chrome, but it recovered (my system let me know as well).
I frequently come across the first problem in Crysis, SCII, and Gmod, but not in WoW or TF2. Any help would be appreciated, especially since I need to send in rebates soon.
Specs, in no particular order (if you want links I'll try to find them):
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor
Mobo: GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD
Case: Antec Three Hundred Illusion Black Steel ATX Mid Tower
OS: Windows 7 Home Premium (Family Upgrade Pack)
RAM: Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
HDD: Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
GPU: XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
PSU: OCZ OCZ750FTY 750W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified
DVD: LITE-ON 24X DVD Writer Black SATA
And I apologize if this is not the right board, but it seemed like the right place for this message.
