Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Realtek HD Audio Noise and Speaker Set Up Issues
Forum CPU & Components : Sound Cards Realtek HD Audio Noise and Speaker Set Up Issues
Hey there,
So I have been having major problems lately with my speaker set up with an on board Realtek HD sound card. I currently use my computer as a Digital Audio Workstation, and all was fine till bout 5 weeks ago...
My computer has always had a buzz when hooked up to the PA System at the studio. (Recently fixed with a DI Box and connecting straight into the snake or Direct lining in to the board) this apparently is 60mhz noise issue.(can be hid by turning off the lows going to the PA). However besides that noise the audio has always been of good quality. At home the quality was perfect, no clicking, skipping, distortion, and all 3 speakers working fine at home.
Well a couple days after bringing my computer home from the studio, I began to hear a small thumb coming from the sub every so often. This begin to increase until it was constant, then my audio began to crack click and pop after that, until it finally died all together. When i restarted my computer the audio worked for a few min then eventually went back to nothing. And eventually the restarting did not even worked. I just assumed i burned out my sound card.
So i borrowed a buddies Creative Live card and it worked. Bad quality sound but it worked. I assumed the bad quality sound was because it was an old card. This card work fine otherwise, the latency was actually better then the Realtek card.
Well the other day this card did the same a the other card. Though all it did was click and skip with a static noise when ever audio played.
Randomly i plugged into my other card activated it and disabled the Creative card. Well it had the same click and cracks as the other card but worked this time. I updated all the drivers and changed the sample rate of it to 24bit 48000k this got rid of click and cracks. I matched the settings in Ableton Live 8 and the clicks went away from there also. But the sound quality is horrible especially when i raise the volume. I can adjust the equalizer settings and speaker setups and volumes to reduce it to a listenable level but its not gone completely. I also noticed the other day that my left channel sound is not playing through my left main speaker. Its playing through the sub. And very low. I'm wondering the reason for the bad sound is due to speaker set up because at the studio all is fine minus a small bit of noise. I have the same noise when playing on other speakers to. I have tried so many fixes already and nothing has helped. Everything from updates - bios settings. Changing my latency in the bios did help the latency of the audio driver though especially with midi.
System Information
Time of this report: 1/27/2011, 05:38:54
Machine name: SHELDON
Operating System: Windows 7 Ultimate 32-bit
Language: English (Regional Setting: English)
System Manufacturer: MSI System Model: MS-7366
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPUE4600 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 2048MB RAM
Available OS Memory: 2048MB RAM
Page File: 1091MB used, 3929MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9600 GT
Manufacturer: NVIDIA
Chip type: GeForce 9600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_23651682&REV_A1
Display Memory: 1267 MB
Dedicated Memory: 499 MB
Shared Memory: 767 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor Name: SyncMaster 2220WM/G22PW/220WM(Digital)
Monitor Model: SyncMaster
Monitor Id: SAM0320
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
Driver Name: nvd3dum.dll,nvwgf2um.dll,nvwgf2um.dll
Driver File Version: 8.17.0012.6658 (English)
Driver Version: 8.17.12.6658
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 1/7/2011 22:27:00, 10078312 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-4562-11CF-306F-69031FC2C535}
Vendor ID: 0x10DE
Device ID: 0x0622
SubSys ID: 0x23651682
Revision ID: 0x00A1
Driver Strong Name: oem24.inf:NVIDIA_SetA_Devices.NTx86.6.1:Section005:8.17.12.6658:pci\ven_10de&dev_0622
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1024 x 768 (32 bit) (29Hz)
Monitor Name: Generic Non-PnP Monitor
Monitor Model: unknown
Monitor Id:
Native Mode: unknown
Output Type: SDTV Dongle
DDI Version: 10
WHQL Logo'd: n/a
Vendor ID: 0x10DE
Device ID: 0x0622
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_14627366&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHDA.sys
Driver Version: 6.00.0001.6278 (English)
WHQL Logo'd: n/a
Date and Size: 12/30/2010 11:59:18, 3351208 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x0745
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC517
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x07FE
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 10/23/2009 23:00:07, 258560 bytes
| Driver: usbd.sys, 7/13/2009 18:51:05, 5888 bytes
+-+ CASIO USB MIDI
| | Vendor/Product ID: 0x07CF, 0x6802
| | Matching Device ID: usb\vid_07cf&pid_6802
| | Service: PL-40R
| | Driver: pl40rwdm.sys, 10/1/2004 15:08:38, 18048 bytes
| | Driver: drmk.sys, 7/13/2009 19:41:37, 80896 bytes
| | Driver: portcls.sys, 7/13/2009 18:51:02, 177152 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/13/2009 18:45:09, 28160 bytes
| Driver: kbdclass.sys, 7/13/2009 20:20:36, 42576 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/13/2009 18:11:24, 80896 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 18:45:08, 26112 bytes
| Driver: mouclass.sys, 7/13/2009 20:20:44, 41552 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/13/2009 20:19:10, 51776 bytes
| Driver: sermouse.sys, 7/13/2009 18:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 6.1 GB
Total Space: 114.5 GB
File System: NTFS
Model: WDC WD1200AAJS-00VTA0 ATA Device
Drive: H:
Model: MagicISO Virtual DVD-ROM0002
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 18:11:26, 108544 bytes
Drive: J:
Model: MagicISO Virtual DVD-ROM0003
Drive: D:
Model: HL-DT-ST BDDVDRW CH08LS10 ATA Device
Drive: G:
Model: MagicISO Virtual DVD-ROM0000
Drive: I:
Model: MagicISO Virtual DVD-ROM0001
System Devices
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_07F0&SUBSYS_73661462&REV_A2\3&267A616A&0&70
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 20:20:45, 12368 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 20:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 20:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 20:26:15, 133200 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_07D3&SUBSYS_73661462&REV_A1\3&267A616A&0&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07C8&SUBSYS_73661462&REV_A1\3&267A616A&0&1C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_056C&SUBSYS_73661462&REV_A1\3&267A616A&0&40
Device ID: PCI\VEN_10DE&DEV_07D2&SUBSYS_73661462&REV_A1\3&267A616A&0&0D
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_056A&SUBSYS_73661462&REV_A1\3&267A616A&0&21
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16445 (English), 10/23/2009 22:58:55, 41984 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 18:51:15, 284160 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16445 (English), 10/23/2009 23:00:07, 258560 bytes
Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_07DC&SUBSYS_366C1462&REV_A2\3&267A616A&0&78
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07D1&SUBSYS_73661462&REV_A1\3&267A616A&0&0C
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_07C3&SUBSYS_73661462&REV_A2\3&267A616A&0&00
Driver: n/a
Name: NVIDIA nForce System Management Controller
Device ID: PCI\VEN_10DE&DEV_07DA&SUBSYS_73661462&REV_A2\3&267A616A&0&1B
Driver: C:\Windows\system32\DRIVERS\nvsmu.sys, 5.10.2600.0208 (English), 3/22/2010 18:29:08, 18944 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvusmu.exe, 1.10.0057.0035 (English), 3/22/2010 12:28:34, 600680 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvsmu.nvu, 3/12/2010 01:31:20, 2054 bytes
Driver: C:\Windows\system32\NVCOSMU.DLL, 1.09.0011.0096 (English), 3/22/2010 12:28:38, 215656 bytes
Device ID: PCI\VEN_10DE&DEV_07D0&SUBSYS_73661462&REV_A1\3&267A616A&0&0B
Driver: n/a
Name: NVIDIA GeForce 9600 GT
Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_23651682&REV_A1\4&2912BE4A&0&0058
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 158312 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 1/7/2011 22:27:00, 281380 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_x86_neutral_e5d9601d40637171\NvCplSetupEng.exe, 14.00.0000.0162 (English), 1/7/2011 22:27:00, 24388856 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/16/2010 13:55:00, 15511 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 10920 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 10467656 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 1/7/2011 22:27:00, 57960 bytes
Driver: C:\Windows\system32\nvapi.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 1965672 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 13011560 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 4941928 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 2251368 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 2895976 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 10078312 bytes
Driver: C:\Windows\system32\nvinfo.pb, 1/7/2011 22:27:00, 4756 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 15047272 bytes
Driver: C:\Windows\system32\nvwgf2um.dll, 8.17.0012.6658 (English), 1/7/2011 22:27:00, 5653096 bytes
Driver: C:\Windows\system32\nvdispco322090.dll, 2.00.0009.0000 (English), 1/7/2011 22:27:00, 941160 bytes
Driver: C:\Windows\system32\nvgenco322040.dll, 2.00.0004.0000 (English), 1/7/2011 22:27:00, 837736 bytes
Name: PCI Input Device
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_07\4&2DADEB9F&0&3950
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07D9&SUBSYS_73661462&REV_A1\3&267A616A&0&1A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07CF&SUBSYS_73661462&REV_A1\3&267A616A&0&0A
Driver: n/a
Name: PCI Express standard Root Port
Device ID: PCI\VEN_10DE&DEV_056F&SUBSYS_73661462&REV_A1\3&267A616A&0&68
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 20:20:45, 153680 bytes
Name: Multimedia Audio Controller
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80221102&REV_07\4&2DADEB9F&0&3850
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_07D8&SUBSYS_73661462&REV_A1\3&267A616A&0&19
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07CE&SUBSYS_73661462&REV_A1\3&267A616A&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_056F&SUBSYS_73661462&REV_A1\3&267A616A&0&60
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_07FE&SUBSYS_73661462&REV_A1\3&267A616A&0&20
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7600.16385 (English), 7/13/2009 18:51:14, 20480 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_07D7&SUBSYS_73661462&REV_A2\3&267A616A&0&18
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 20:20:43, 13888 bytes
Device ID: PCI\VEN_10DE&DEV_07CD&SUBSYS_73661462&REV_A1\3&267A616A&0&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_056E&SUBSYS_73661462&REV_A1\3&267A616A&0&58
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_07FC&SUBSYS_73661462&REV_A1\3&267A616A&0&48
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 18:50:56, 108544 bytes
Device ID: PCI\VEN_10DE&DEV_07D6&SUBSYS_73661462&REV_A1\3&267A616A&0&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_07CB&SUBSYS_73661462&REV_A2\3&267A616A&0&01
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_056D&SUBSYS_73661462&REV_A1\3&267A616A&0&50
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,gzHF330.ddc,1.01.0000.0017
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16597
QuickTime Video Decoder Filter,0x00600800,1,1,mtw178.ddc,1.01.0000.0017
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,2.06.4037.0000
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
AAudioRipper,0x00200000,0,0,AudioRipper.ax,
CyberLink HD/BD Mixer,0x00200000,1,2,CLHBMixer.ax,2.00.0000.1810
CyberLink MPEG Video Encoder,0x00200000,1,1,P2GVidEnc.ax,6.00.0001.2226
CyberLink Editing Service 4.5 (Source),0x00200000,0,2,CLEdtKrn.dll,4.05.0000.1812
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,SE_CLEdtDemuxer.ax,1.02.0001.6529
CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
PP TV Audio Decoder,0x00200000,1,1,claudTV.ax,6.01.0000.4227
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.5113
CyberLink Editing Service 3.0 (Source),0x00200000,0,2,P2GEdtKrn.dll,3.00.0000.2911
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.6529
CyberLink AudioCD Filter (PDVD7),0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.4602
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.02.0001.2929
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
CyberLink Audio Decoder,0x00201000,1,1,Claud.ax,6.03.0000.1902
PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.0000.5608
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,2.00.0000.2419
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CyberLink Audio Effect (PDVD7),0x00200000,1,1,CLAudFx.ax,6.00.0000.6525
WMT Screen Capture filter,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
PP Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
P2G Video Decoder,0x00200000,2,3,P2GVSD.ax,6.00.0000.2310
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16648
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
PP Dump Filter,0x00200000,1,0,CLDump.ax,3.00.0000.8231
CyberLink MPEG-4 Splitter,0x00200000,1,2,SE_clm4splt.ax,1.00.0000.5210
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
CyberLink SAC Video Decoder(PDVD7 HomeNetwork),0x00200000,2,3,CLVSD.ax,6.00.0000.2122
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
DivX MKV Demux (unrestricted),0x00200000,0,1,DMFSource.ax,1.00.0002.0006
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
P2G Audio Decoder,0x00200000,1,1,P2GAud.ax,6.01.0000.3601
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
CyberLink Mux Push Source,0x00200000,0,1,SE_CLMuxPushSrc.ax,1.00.0000.0822
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
CyberLink Video Effect,0x00200000,1,1,P2GVidFx.ax,1.00.0000.2030
PP TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1917
CyberLink Demux (PDVD7),0x00602000,1,0,CLDemuxer.ax,1.05.0000.6909
CyberLink MPEG Splitter(Scramble),0x00200000,1,2,CLSplter.ax,3.01.0000.1424
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
CyberLink AVCHD Navigator,0x00600000,0,3,CLAVCHDNav.ax,2.00.0000.2623
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.2910
Record Queue,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CyberLink Line21 Decoder (PDVD7.x),0x00200000,0,2,CLLine21.ax,4.00.0000.10309
CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
WMT Audio Mixer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
PP Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1926
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.01.0000.2928
CyberLink MPEG-2 Splitter,0x00200000,1,2,P2Gm2spliter.ax,2.04.0000.2301
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
PP MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.01.0000.2014
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,1.00.0000.3702
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
Frame Eater,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Cyberlink Dump Dispatch Filter,0x00200000,1,0,P2GDumpDispatch.ax,1.02.0001.2412
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,9.00.0001.0021
CyberLink Push-Mode CLStream (PDVD7),0x00200000,0,1,CLStream(PushMode).ax,1.00.0000.1524
CyberLink Audio Decoder (PDVD7 UPnP),0x00200000,1,1,CLAud.ax,6.01.0000.3613
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
CyberLink MPEGV Analyzer,0x00200000,1,1,SE_CLMPEGVAnalyzer.ax,1.00.0000.1725
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
CyberLink Audio Spectrum Analyzer (PDVD7),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
CyberLink SBE Source Filter,0x00200000,0,0,CLSBESrc.ax,1.00.0000.3628
Cyberlink Dump Dispatch Filter,0x00200000,1,0,SE_CLDumpDispatch.ax,1.03.0000.1003
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
CyberLink MPEG-1 Splitter,0x00200000,1,2,P2Gm1spliter.ax,2.04.0000.2301
CyberLink Stamp Effect,0x00200000,1,1,ppStampEffect.ax,1.00.0000.2108
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.6318
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVsd.ax,8.04.0000.0730
Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
CyberLink TL MPEG Splitter,0x00200000,1,2,SE_CLTLMSplter.ax,3.02.0000.4316
CyberLink M2V Writer,0x00200000,1,0,P2GM2VWriter.ax,1.03.0000.2017
PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.01.0000.0213
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,2.06.4037.0000
Cyberlink Dump Filter,0x00200000,1,0,P2GDump.ax,3.00.0000.7122
CyberLink Video Stabilizer,0x00200000,1,1,P2GVideoStabilizer.ax,1.00.0000.1017
CyberLink Audio Decoder,0x00200000,1,1,SE_claud.ax,8.01.0000.3631
PP Audio Decoder,0x00200000,1,1,CLAud.ax,8.01.0001.3905
CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
CyberLink DVD Navigator (PDVD7),0x00200000,0,3,CLNavX.ax,8.00.0000.3224
CyberLink TimeStretch Filter (PDVD7),0x00200000,1,1,clauts.ax,1.00.0000.5423
PP MPEG Splitter,0x00200000,1,2,ppSplter.ax,3.03.0000.1917
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
Cyberlink SubTitle Importor,0x00200000,2,1,CLSubTitle.ax,1.00.0000.6519
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.1805
DivX MKV Demux,0x00600000,0,1,DMFSource.ax,1.00.0002.0006
CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,2.00.0000.1521
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
CyberLink H.264/AVC Decoder,0x00200000,1,2,cl264dec.ax,2.01.0000.1708
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
WMT DirectX Transform Wrapper,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
CyberLink MPEG-4 Splitter (PDVD7),0x00600000,1,2,clm4splt.ax,1.00.0000.4409
9x8Resize,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,2.06.4037.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
CyberLink MPEGV Analyzer,0x00200000,1,1,CLMPEGVAnalyzer.ax,1.00.0000.1725
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
CyberLink TimeStretch Filter (CES),0x00200000,1,1,P2Gauts.ax,1.00.0000.2212
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
CyberLink TL MPEG Splitter,0x00200000,1,2,P2GTLMSplter.ax,3.02.0000.2219
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CyberLink MPEG Muxer,0x00200000,2,1,P2GMpgMux.ax,5.01.0000.1723
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
PP Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1716
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,1.00.0000.2617
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
CyberLink SBE Filter,0x00200000,0,0,CLSBE.ax,1.00.0000.3628
CyberLink MPEG Muxer,0x00200000,2,1,SE_MpgMux.ax,5.01.0000.1916
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
P2G Video Regulator,0x00200000,1,1,P2GResample.ax,2.05.0000.1818
CyberLink MPEG-4 Muxer,0x00200000,1,1,SE_clm4muxer.ax,1.00.0000.3920
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
PP MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,6.03.0001.3201
CyberLink Demux (PDVD7 UPnP),0x00200000,1,0,CLDemuxer.ax,1.00.0000.3421
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
WMT Volume,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Stretch Video,0x00200000,1,1,WMM2FILT.dll,2.06.4037.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.4024
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
CyberLink Streamming Filter (PDVD7),0x00200000,0,1,CLStream.ax,1.01.0000.1524
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
CyberLink MPEG Decoder,0x00200000,2,3,P2GMVD.ax,5.00.0000.0929
CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.4506
CyberLink MPEG-4 Muxer,0x00200000,1,1,clm4muxer.ax,1.00.0000.3126
Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Track Compressor,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1471
Sony Dither,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1471
Sony Chorus,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Distortion,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
Sony Gapper/Snipper,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
Sony Simple Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Reverb,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Multi-Tap Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Track Noise Gate,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1471
Sony Graphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Track EQ,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1471
Sony Smooth/Enhance,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
Sony Resonant Filter,0x00200000,1,1,sfresfilter.dll,1.00.0000.1470
Sony Parametric EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Time Stretch,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Noise Gate,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Paragraphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Vibrato,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
Sony Pitch Shift,0x00200000,1,1,sfppack1.dll,1.00.0000.1466
Sony Flange/Wah-wah,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
Sony Graphic Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.1466
Sony Amplitude Modulation,0x00200000,1,1,sfppack3.dll,1.00.0000.1466
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.9.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16648
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
Midi Renderers:
3- MK USB IN 1,0x00200000,1,0,quartz.dll,6.06.7600.16490
3- MK USB OUT 1,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
USB O2,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Capture Devices:
Line in at front panel (Green),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Mic in at front panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (black),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (Blue),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (Green),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (Grey),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (Orange),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Line in at rear panel (Pink),0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Realtek HD Audio CD input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
USB O2,0x00200000,2,2,ksproxy.ax,6.01.7600.16385
MK USB IN 1,0x00200000,2,2,ksproxy.ax,6.01.7600.16385
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
,0x00000000,0,0,,
MK USB OUT 1,0x00200000,2,2,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16648
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7600.16490
CyberLink Audio Renderer (PDVD7.x),0x00200000,1,0,cladr.ax,7.00.0000.1906
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16490
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Reply to jadamtallman
Congrats on the longest post ever!
Right, what soundcard do you use (or have you tried), what motherboard and graphics card, and what PSU?
Reply to mi1ez
Well thanks on the congrats!!!
*points up* all the info u could ever need is above lol.
but it's an msi mother board. realtek hd audio on board sound card and a Crative Live pci mk-(something) sound card that is currently disabled. A nivida 9600gt graphics card. and a 450 watt power supply though i am not sure of model. I'll have to check when i get home.
I'm just thinking that a bad powersupply could generate noise, and maybe even a graphics card (especially if it's at 60Hz!)
Is there any way you could check with on-board graphics or a different PSU?
Reply to mi1ez
yes it is 60hz! sorta.
at the studio both are computers register noise at 60hz a DI Box fixed my PA issues at the studio with background noise. Clicks and cracks still remain. The DI Box has no effect at home. Don't know if its because I am not plugged in to a board here? Your right a bad powersupply could be noise. But is that not like a ground loop? Does it make clicking cracking and stuttering or just noise?
I tried taking my graphics card out and running just on board and shutting on board off and running other and still the same. Switching PCI slots and so on. Right now the creative sound card is the farthest PCI slot away from the PSU. I really hope its not PSU issue. IS there anyway i can find out?
Right now my audio is okay for the most parts. The highs are really high and lows are really bassy. When i switch effects on things in Ableton i heare a "scratch sound" for a moment in audio. And on some digitized sound it clicks. I'm kinda thinking now it might be memory issue. But I'm pretty sure I have more than enough to run Ableton 8.
poop
Sorry, got me stumped now!
Reply to mi1ez
There are 1681 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 2 hours ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
