I am planning to run a pair of Radeon HD 4870 cards in a CrossFire configuration. The manufacturer's website says that two of these cards is compatible with an Antec TPQ 850 power supply, but how can that be? Each card has two 6-pin power inputs, for a total of four 6-pin power connectors. The power supply has only two 6-pin power outputs. How can I connect the two power connectors from the power supply to the four total power inputs on the cards? Does each card only need one power input when run as a CF pair?
