Solved
Power Supply Guides and UPS info
  • Power Supplies
  • Fan
  • Components
  • Product
Last response: in Components
January 27, 2011 3:20:32 PM
A big fan of this site. I have found almost all my answers by reading this forum, thanks. Now a question:
I have an Asus cm5571 desktop from best buy. Really been a good computer the last year. I bought a Gforce Nvidia gt220 graphic card right when i bought the pc. for what i do, online racing, it works real well. I also added a front intake fan, and rear exhaust pci fan. I read on here about upgrading the power supply, so now i am ready to do that. I am looking into a corsair gs600 ps.
What i want to do is upgrade power supply, add side panel window and fan, install second dvd / rewriter. But, the case is getting cramped. Is it possible to transfer all my coponents to a mid tower? Also, on this asus i really like the front cover, spring loaded door for the dvd drive. Also has a hide away door that has front usb, headphone/mic. jacks, and media card reader. If I can upgrade to a mid tower, can i transfer the front ports or do i have to find a case with them built in? Any suggestions on a case that has a front cover and media ports like the one i have? Also on the specs. of this it says it has built in keyboard LED panel? what is that? Any direction on PS would be appreciated. Thanks
More about : power supply guides ups info
Best solution
a b ) Power supply
February 2, 2011 1:18:27 AM
Hello, and welcome to THG.
You may transfer your components form your previous unit to another chassis. You cannot, however, exchange front ports at all.
Here are some cases I recommend:
February 2, 2011 6:12:22 PM
Thanks for the response. I think I am going to use one of those.
m
l
February 2, 2011 6:16:06 PM
Best answer selected by ckracefan41.
m
l
