I'm trying to figure out if a power supply will work with a system i am building. I have used a few of the calculators and the general amount is a 750w
I have never needed one this big before so i thought i would ask people who knew
This is the power supply im thinking of using [CORSAIR CMPSU-750TX 750W] - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CPU
- Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W
Motherboard
- ASUS P8P67 PRO LGA 1155 Intel P67
Graphics Card
- GIGABYTE GV-N465MT-1GI GeForce GTX 465 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16
Memory
- G.SKILL Ripjaws Series 4GB 240-Pin DDR3 1333
Optical Drive
- LG Black Blu-ray Disc Combo SATA Model UH10LS20 LightScribe Support
Case
- Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case (Comes with 5 fans (3 blue 120mm) + (120mm) + (1blue 140mm)
HD
- Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s
I am planning on getting 4 sticks of the ram and eventually 2 of the drives.
I just really want to be sure that the system will work and wont need a power suppy upgrade in the future. And that it will also be able to power thumb drives and a new cpu fan later on.
Thanks a lot guys your the best!
CPU
Motherboard
Graphics Card
Memory
Optical Drive
Case
HD
